Old 06-22-2008, 06:53 PM   #1
Rennzenn
j.fro's Avatar
CEL code P1531
Anyone have experience wit this code?
Old 06-23-2008, 08:25 AM   #2
All I know is that it's a bank 1 camshaft adjustment short circuit (http://www.iequus.com/support/obd2_definitions.php) -- maybe someone here can offer the diagnostics procedure.
Regards,
paul...
paulv is offline   Reply With Quote
Old 06-23-2008, 09:05 AM   #3
That's the VarioCam actuator solenoid valve on the passenger side (Bank 1 like paulv said).
I just had mine replaced last month for approx. $1300. The engine does not have to be dropped. The coil-packs and plug tubes are removed, 2 bolts on the VarioCam cover removed, 4 bolts on the oil-pump removed, 23 bolts on the cylinder cover removed and then 2 bolts attach the solenoid to the actuator.
The solenoid itself is about $180. The pin/plunger on mine would move only a fraction of an inch when 12 volts was applied- I checked after it was removed.
Download this file...
http://www.cannell.co.uk/Boxster_Manuals/986%20Group%200a%20Diagnosis%20To%2045.pdf
Go to page 24 45-D for the diagnostic procedure.
I was getting 12v at the connector so the wiring was good up to the solenoid.
PM me if you have any other questions.
Regards,
mike
derb is offline   Reply With Quote
