Old 06-18-2008, 07:09 AM   #1
Obc
i have a 986s with the instrument cluster that has the detailed display
whats the best way to access its functions as i do not have the 4th obc stalk...
ralphie is offline   Reply With Quote
Old 06-18-2008, 07:36 AM   #2
Lil bastard's Avatar
I think you'd be happiest adding the 4th stalk. These are readily available from wreckers and you can use one from either a 996, 986 or even a 993 (though w/ the 993, you need to modify the connector).
The 4th stalk is the only one which detaches from the main cluster - it just screws on, but of course, not available separately from Porsche. It will screw onto your existing 2 or 3 stalk cluster, then wire it in using the excellent write-up from our own Tool Pants.
It'll give you a stock appearance, and IMHO, is easier to operate w/o taking your eyes off the road.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 06-18-2008, 07:44 AM   #3
this was originally my idea..
but then i bought a 3 stalk obc (w/o cruise) from the net, took it to a garage that serviced porsches and mechanic said that the plugs were different and couldn't fit it
should this be the case? or can i still use the stalk and 'modify' it?
TIA
Old 06-18-2008, 07:53 AM   #4
do you have a link for the write up? cheers
Old 06-18-2008, 09:14 AM   #5
If you have a 3-stalk cluster, you'll find a PN # on it. I suspect it will start with 993 (if the connectors are incompatible). Also, you'll see that the OBC stalk will detach from the rest of the unit - it just screws off.
Were it me, I'd remove the 3rd stalk, implant it on the OEM cluster on your car and do one of 2 things. I'd either find the compatible Molex connector for your car and transplant it to your new stalk, or get a generic Male and Female 4 wire (? IIRC) connectors and splice them in place of the stock Molex connectors. Pretty easy to do. Also, you'll want to cut the rubber cover on the escutcheon to accept the additional stalk with a razor blade or such.
Here's the write-up:
http://www.whiteson.org/boxster/mods/obc/obc.stalk.pdf
1976 BMW 2002
1990 BMW 325is
Old 06-18-2008, 10:52 PM   #6
TIA
Need to see a picture of what you bought.
Old 06-19-2008, 05:07 AM   #7
996 613 215 00
how do i post a picture?
Cheers
Old 06-19-2008, 05:15 AM   #8
