Old 06-09-2008, 09:41 AM   #1
Convertible Storage Compartment
I really don't know the exact name, but the rear storage that opens up and the convertible top slides in when open, for some onknown reason mind is stuck and won't open, makes noises but won't open, need help from anyone that has experience this problem.thanks
bonvita1973 is offline   Reply With Quote
Old 06-09-2008, 02:09 PM   #2
rdancd816's Avatar
What year is your Boxster? I have a 1997 that snapped the transmission cables for the roof and resulted in the clamshell not moving. If it is in the "down" position and the cables are bad you are lucky. Often these break when moving the top and bend the clamshell. This is common on older 986's. Check Randall's website for more info. I paid the stealership $1500 to replace the broken cables. My clamshell was not bent as I stopped the top immediatly when I saw the clamshell begin to flex. Good luck.
"97 Boxster" Guards Red, Coppell, TX 36,500 miles
2010 Mazda CX-7 AWD, Turbo, Grand Touring
rdancd816 is offline   Reply With Quote
