Old 05-30-2008, 12:29 PM   #1
Wierd, Scary Noise...What is it?
Whenever I drive around, for the past few weeks now, I've been hearing a wierd noise come from (what sounds to be) behind the passenger seat. It almost sounds like someone put a ball back there and when I slow down or accelerate it rolls around and hits things (I know this clearly isn't the case, but it gives you an idea of what I am hearing.)
Anyone have any ideas? It kind of worries me. Car drives fine, but you know how these things go. Its a clunking noise one minute and a dead car the second!
1997 Boxster, 60K miles
ChrisH027 is offline   Reply With Quote
Old 05-30-2008, 01:31 PM   #2
If you push the clutch in (or put it in neutral) and coast, then hit the brakes, does it still make the sound? Or does it just make the sound when you accelerate and slow down using the engine, in gear?
Accell/decell torque on the engine with a bad motor mount could make some noise. If the clutch in/neutral test stops the noise, it would seem to be motor/driveline related.
If it still happens with the clutch in while hitting the brakes, you're likely looking at something in the suspension.
Hope that helps.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
Old 05-30-2008, 01:38 PM   #3
Brucelee's Avatar
Hope that helps.
Ditto on this. Would be good to get the car up on a lift and check it out. I would not wait long.
Rich Belloff
Old 06-02-2008, 07:18 AM   #4
Ok so here is an update on this...
It happens when the clutch is in, and I am in neutral. What kind of suspension problem could I be looking at?
Old 06-06-2008, 09:15 AM   #5
ppbon's Avatar
My guess is a worn Front Engine Mount.
I've seen and heard plenty of those.
Happy Boxstering,
Pedro
ppbon is offline   Reply With Quote
Old 06-06-2008, 09:25 AM   #6
bmussatti
Posts: n/a
Happy Boxstering,
Pedro
Pedro, our engines are in the middle of the car.
Old 06-06-2008, 10:32 AM   #7
Bill, you're a sharp one today.
Chris, what model year car and mileage do you have on your boxster? <--- information that should be in your signature line, btw...
Old 06-06-2008, 01:03 PM   #8
Sorry Randall
I have a 1997 Boxster with 60k miles!
Old 06-06-2008, 02:46 PM   #9
tboyer's Avatar
For me, the last noise I had behind the passenger seat was coming from a bad water pump
'06 Cayman 'S' - Sold (Sport Chrono, PASM, TPMS, 19' CAS Wheels, NAV)
'06 Cayenne - Sold
'01 Boxster 'S' - Sold
'00 Boxster - Sold
tboyer is offline   Reply With Quote
Old 06-06-2008, 06:19 PM   #10
ppbon's Avatar
I did not know that!
Now, did you know that our Boxer engine is mounted backwards from the 911?
That's why 911s don't have Front, engine mount issues like we do.
Happy Boxstering,
Pedro
