Old 05-12-2008, 05:25 PM   #1
Power Loss in 5th Gear
While cruising in 5th gear at approximately 70mph I noticed the car beginning to slow. I began to give the engine more gas and the RPM and speed of the car continued a slow decline. I shifted to 4th and then 3rd while attempting to gain RPM and maintain speed. Even with the car in neutral, I was unable to rev the engine or create any change from idle. When I pulled the car off the road it idled in neutral and there were no unnatural noises or knocks. I then turned the car off and, after checking for fluid leaks and unnatural smells, I started the car. I was able to throttle up and control RPMs just as I normally would. The car performed beautifully for another 45 minutes before the same problem arose. The car then ran 2.5 hours without any problem in 5th gear on the highway under normal driving conditions. No warning lights ever illuminated and so far no one has been able to answer my question as to what went wrong. I surmised a computer/electrical issue since the problem was removed by turning the car off and restarting. The throttle linkage is in fine working order and there are no other obvious physical signs of wear or damage to the engine. Has anyone else had a similar problem or can anyone point me in the direction of the problem/solution?
luke1834 is offline   Reply With Quote
Old 05-12-2008, 06:25 PM   #2
Porscheectomy
What is your cars model and year?
Old 05-12-2008, 06:33 PM   #3
Sorry, new to all this and got caught up writing about the problem. I have a 99 Boxster
Old 05-13-2008, 06:18 AM   #4
Consider the fuel filter - when was it last changed?
Kevfra is offline   Reply With Quote
Old 05-13-2008, 07:07 AM   #5
You may want too check your MAF unit. That happened to me when I first purchased my Boxster and the problem turned out to be the sensor..
catmanluge is offline   Reply With Quote
Old 05-13-2008, 10:49 AM   #6
I thought about the MAF but the question arose: Would the problem be confined to 5th gear and be so intermittent? I know I have a throttle cable and not e-gas which rules out a throttle body and I am hesitant to have my mechanic run a diagnostic in fear of "Trouble not identified" since the CEL never came on. I can replace the MAF but would like to avoid the cost if unnecessary. Is there anyway to check the MAF wihtout running a diagnostic? I am a Mechanical Engineer but have limited experience working on vehicles.
Thanks for the help,
Luke
Old 05-13-2008, 11:14 AM   #7
Porscheectomy
Luke
It doesn't sound to me like it's related to 5th gear directly, but related to time and potentially temperature. I'd tend to suspect the fuel pump first. It could be that the air temperature sensor (part of the MAF) is malfunctioning as the car warms, but that wouldn't be my first attempt. The dealer may be able to measure current draw from the fuel pump when it's warm to see if there's a problem. What's the mileage on the car?
I'm an ME too, go Boilers!
Old 05-13-2008, 12:27 PM   #8
The mileage is 84k with service at all recommended intervals. I knew the previous owners and they took excellent care of the vehicle. The temp could be a key, the only time the car faulted during daytime running on the highway (about 80F outside temp). I drove it at night for a total of 3-4 hrs this weekend and nothing out of the ordinary happened. What I keep coming back to is the lack of a CEL. Would the MAF or fuel pump trigger a CEL with a fault like that? Are there any other conditions that would cause the engine to default to idle and remove throttle control?
Go Tigers!!
