Old 04-26-2008, 04:20 PM   #1
thicker oil
Ive got a dozen qts. of Mobile 1 15-50 in the garage should I use them for the next change. 02 3.2 48,000.
986chris is offline   Reply With Quote
Old 04-26-2008, 04:57 PM   #2
Porsche's original reccomendation for the Boxster S 3.2L was 10W40/15W40/15W50 for temperatures higher than 50F. However they've since revised their recommendation to 0W40.
I would say you're probably OK to use it, but 0W40 is preferable.
John V is offline   Reply With Quote
Old 04-26-2008, 05:51 PM   #3
bmussatti
Posts: n/a
I agree with John V. Porsche's only 50 weight approved oil is Mobil One's 5W50 right now.
How old is the oil in the garage?
Old 04-26-2008, 11:36 PM   #4
Lil bastard's Avatar
It's totally fine for 50°F + driving.
The only issue you're likely to see is a slightly reduced Range (MPG).
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 04-27-2008, 04:03 AM   #5
John, it's probaly 9 months or so.
Old 04-27-2008, 05:08 AM   #6
I know Porsche now use 0W40 Oil for year round use. If you only drive your Box in warm weather I guess you're O.K. because the 15W will never be factor. But the higher the Viscosity the more resistance to flow the oil will have and the more wear at every start-up you will have after the car has been sitting for a couple of hours and the oil has all run back down into the pan.
http://i25.tinypic.com/20aq3wn.jpg http://i26.tinypic.com/2zguetx.jpg http://i28.tinypic.com/2jdi1ok.jpg
2000 Boxster S: 18" Turbo wheels w/color crests, Litronics, Onboard Computer, Traction control, Cruise, Painted rollbar, Leather interior, Aluminum package, headlight washers, Porsche GT3 seats, windstop, Hi Fi six speaker amp package, DSP, CDR 220, Limited Slip, side airbags, BK Rollbar extender.
2000SoCalBoxsterS is offline   Reply With Quote
Old 04-27-2008, 06:11 AM   #7
Porscheectomy
Variable valve timing systems depend on oil pressure for correct activation. If the pressure or flow is too low the system will not function as designed.
Old 04-27-2008, 07:08 AM   #8
Brucelee's Avatar
If I lived in where you do, I would only use this oil in Summer. Perhaps you could use it from May-Oct and switch to 0-40W?
Rich Belloff
Old 04-27-2008, 10:39 AM   #9
I have used 15W-50 for the 9 years I have owned my Boxstir.
http://www.renntech.org/forums/index.php?showtopic=9454&hl=unapproved
I used the EP flavor for the last oil change because the regular 15W-50 had been discontinued. But since then Mobil has brought it back to the market.
While I may not be going to Porsche heaven, my 1997 runs fine.
If you don't want it send it to me.....
Old 04-27-2008, 05:27 PM   #10
tool pants did u take that foto just 4 me. btw i'm also doing track days/autox events 2. so u al have made up my mind, i'll use it! tanks al.
Old 04-28-2008, 03:12 AM   #11
Who's al?
Old 04-28-2008, 07:42 AM   #12
This one I took for you....
Old 04-28-2008, 11:38 AM   #13
Brucelee's Avatar
As I understand it, synthetic oil is derived from foodstuffs.
So, maybe the one on the left is the pick?
Rich Belloff
