Old 04-24-2008, 08:19 PM   #1
update on exhaust issues... can anyone help?
Some of you have read my other posts about my exhaust. I think I'm getting close to solving, I have a new check code. My exhaust is on a 00' S, set-up is Che's headers, Fabspeed test pipes, Che's exhaust. Yes that means I have no cats. Che sent me 02 sensor cheaters... the ones that back the 02s out of the exhaust pipe. The rear sensors I just plugged in and zip tied them up and out of the way. The 02s are new so is my maf. The check code is now p1115. Something about pre heating the 02s? Help me please. and thank you.
00' Porsche Boxster S
99' Subi 2.5 rs
00' Audi A4/S4
(www.myspace.com/tcechelon)
mn box s is offline   Reply With Quote
Old 04-25-2008, 04:24 AM   #2
Rennzenn
j.fro's Avatar
You may have a bad O2 Sensor. You can check this by switching them (move left one to the right, and right to the left). Clear the codes, and go for a drive. If you get a CEL with a 1119 code, then it's the sensor. 1119 is the same code as the 1115, just for the other side.
j.fro is online now   Reply With Quote
Old 04-25-2008, 05:04 AM   #3
front? rear? or both?
99' Subi 2.5 rs
00' Audi A4/S4
Old 04-25-2008, 07:02 AM   #4
I currently have a similar issue- I have both P115 and P119. I bought new O2 sensors after my header install and both codes came up. I found a thread on another forum that said the resistance on the two heating wires should be between 1.8 and 2.5 ohms. My new ones were 3.4. The old ones were 2.5. I contacted the manufacturer (SNG) and they said my new ones were defective. I returned them but have not purchased another set yet.
Might be worth it to check the two white wires on both sides.
Good luck.
derb is offline   Reply With Quote
Old 04-25-2008, 10:54 AM   #5
I don't want to rule that out entirely, mine are Bosche exact replacements oem. I want to say that its probably not my problem. How do I go about testing the resistance I have a expensive fluke that willm do the trick. Was this from your rears or your fronts??? my guess is its from my rears that are not in any pipe currently??? Can anyone else chime in???
99' Subi 2.5 rs
00' Audi A4/S4
Old 04-25-2008, 01:49 PM   #6
P1115 is the pre-cat, passenger side sensor. The fluke will work in testing resistance. O2 sensor heating code issues seem to be popular. I'm trying resolve mine too.
2000 Boxster S
http://www.slipangle.com/images/ACSpeed_sig.jpg
heyjae is offline   Reply With Quote
Old 04-25-2008, 04:28 PM   #7
Jaxonalden's Avatar
O2 Sensors
This is just my opinion. To do their job, your O2 sensors need to read the O2 levels. The sensors are different before and after the cats because the resistance will be different when reading the exhaust gases because of the temp of the re-burning of the hydrocarbons. That re-burning confirms (through the O2 sensor) that the engines computer has the correct air/fuel ratio for the current conditions. When the oxygen sensor fails (or in your case removed and not reading the O2 in the exhaust), the computer can no longer sense the air/fuel ratio, so it ends up guessing. Your car performs poorly and uses more fuel than it needs to. It will also throw up a code to your computer saying "the O2 sensor is bad".
You wrote "The rear sensors I just plugged in and zip tied them up and out of the way". Those sensors aren't reading a thing! No wonder they threw a code.
Old 04-25-2008, 08:37 PM   #8
I realize. No cats here. Most people that run no cats will tie the rears up. I guess my next step is to weld in bungs for the 02 and try another set of cheaters on those. From what I have understood though was that the wide band 02s are the front ones and the closed loop 02s are the rears to double check whats going on in front of them. Thats why on other cars you can get away with tying them up.
99' Subi 2.5 rs
00' Audi A4/S4
Old 04-27-2008, 09:13 AM   #9
Jaxonalden's Avatar
I don't know the particulars about what parameter each O2 sensor monitors, but I do know that the ECU needs inputs. Those inputs include the O2 senors and if their transmitting bad info, or info out of tolerance, it will flag a code and the engine will not run efficiently.
I hope someday a computer nerd will develop some software that will allow the Boxster the use of running with no cats (off road use only officer ). Sounds simple to me.
Old 04-28-2008, 09:09 PM   #10
So are there no computer flashes that can correct this problem?
99' Subi 2.5 rs
00' Audi A4/S4
Old 04-28-2008, 09:29 PM   #11
Ya, its called the european tune. Just flash it with a ROW computer and it doesn't read the cats. An australian member runs catless because of this IIRC
SilentThunder is offline   Reply With Quote
Old 04-28-2008, 09:52 PM   #12
I've been around here for awhile and seen the abbreviation ROW before... what is it?
How do I go about doing this flash tune? Can I change other parameters. Can I do the tune then chip the car? Suppose I have to send my ECU out
99' Subi 2.5 rs
00' Audi A4/S4
Old 04-29-2008, 06:57 AM   #13
ROW - Rest of the World ( outside of the US )
Nick
1999 986 ( Black )
1998 MB C280 ( Black )
1999 BMW K1200RS ( Yellow )
2005 Audi A4 ( Red )
Old 04-29-2008, 10:00 AM   #14
Ok so do I drive around the world? Thanks about the ROW but seriously that doesn't help me thank you.
99' Subi 2.5 rs
00' Audi A4/S4
Old 04-29-2008, 10:10 AM   #15
As you already know that ROW stands for "Rest of the World"... to elaborate on this term for you, There are 2 types of boxsters... US spec Boxsters, and ROW boxsters.... US Spec boxsters have tighter Smog requirements and less aggressive/softer struts, springs & swaybars and settings than the ROW Boxsters.
Does that make sense, ROW Boxsters are sold EVERYWHERE but the USA.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 04-29-2008, 10:27 AM   #16
Porscheectomy
You WANT the forward O2 sensors in the exhaust stream. This makes corrections in mixture during closed-loop operation. Don't use a cheater on these, use a normal bung.
For the rear sensors, if you can't get a reflash, you can replace the sensor with a circuit that tricks the ECU into thinking all is well. I've posted it here before if you're interested you should be able to search for it.
Old 04-29-2008, 08:28 PM   #17
Jaxonalden's Avatar
As you can see, we here in the US are the ones that are being restricted as to the true performance potential of the Boxster motor. The trick is to get the Euro tune on our Boxster's and then avoid the sniff check from your state. I'd love to get the flash on my '04 S but I don't know exactly how to go about it.
So I hope with the help of these posts you understand your problem a little better. I learn something new (trust though verified) from other Boxster owners. This is an invaluable website for help. Thanks y'all for your inputs.
We should all get together sometime.
Old 04-29-2008, 11:12 PM   #18
Yes every thing makes sense... I still have the questions where do I get the reflash for ROW. Can I do the ROW and still chip my car...
I bought from the Mac guy today an obd2 code reader and eraser just to keep in the glove box so I can clear my exhaust codes.
99' Subi 2.5 rs
00' Audi A4/S4
Old 04-30-2008, 06:04 AM   #19
^^ do you have any advice on who would be able to flash it with the ROW software? I mean the dealer (i have a good relationship with), would they be able to get the ROW software, or do they just have access to the US software?
jackhoff is offline   Reply With Quote
Old 04-30-2008, 06:42 AM   #20
All the maps are in the PST2/PIWIS, anybody (like myself) who has these tools can reflash the DME as long as the DME code is provided. I doubt a dealer will do it for you, as it is not legal for street use to run the ROW program here in the US.
You don't 'chip' these cars, they are reflashed with new maps by aftermarket tuners the same way the different factory maps are flashed, through the OBD port. Thus if you put an aftermarket 'chip' in there, it will overwrite your ROW map. Thus you would need a 'performance' map that also ignores the after cat O2 input.
-Todd
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
tholyoak is offline   Reply With Quote
