Old 03-20-2008, 05:38 PM   #1
My top is stuck in the down position.
Is there an FAQ thread or website on this? When I press the close top button, nothing happens and I do have the ebrake pulled..
Nick
SinnerDC2 is offline   Reply With Quote
Old 03-20-2008, 08:11 PM   #2
Lil bastard's Avatar
Couple of things.
E-brake pulled, but do you have the E-brake light on the dash? Could be the micro-switch. Try working the E-brake several times until you get the light.
Also, could be the micro-switch in the windshield header. Take a pencil, popcicle stick, chop stick or any thing soft (metal not recommended) and insert it in the hole for the Top Latch pushing and releasing to make sure the switch is closing. Make sure this switch is working - they do stick occasionally.
Finally, check appropriate fuses - B6 - control, D3 - motor, and also make sure convertible top relay is snug in the relay box - it's the only double-sized one in there - #14-15.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 03-20-2008, 09:38 PM   #3
yup it was the ebrake switch. good call
http://www.renntech.org/forums/index.php?showtopic=5543 this is a good topic on tops and has a pdf for debugging the problems
Old 03-21-2008, 12:37 PM   #4
it usually is the e-brake switch. Mine is still finicky and wont work occasionally.
kabel
kabel is offline   Reply With Quote
