-   -   Problems after O2 install...need help (http://986forum.com/forums/performance-technical-chat/15350-problems-after-o2-install-need-help.html)
cmccloud 02-08-2008 08:19 AM
replaced all 4 O2 sensors on 1999 boxster....car now runs very rough, pops, misfires, no power, stalls...tried unhooking battery as I have done before so ECU would reset to factory baseline and re-learn correct fuel mixture parameters with new sensors....no luck yet...am I missing something...any helpful suggestions would be greatly appreciated.....Car is not yet throwing any new codes...I reset CEL with scanner before starting... after sensor install...
dcporsche99 02-08-2008 11:58 AM
Hi again...you might want to delete this one since you have posted the same thing twice. :cheers:
I posted a response on the other one.
Also, try to be patient....others will respond. ;)
