Old 01-10-2008, 10:31 AM   #1
911 (996) Instrument cluster to 986
I'm looking for info on swapping my 986 instrument cluster for a 911 (996) cluster. I saw this done at the RUF factory and I've heard about others doing it. Any info out there?
jrudolph is offline   Reply With Quote
Old 01-10-2008, 11:15 AM   #2
Did you try a search? 2 people on this site have done it for sure. They both had some problems with the fuel gauge reading properly afterwards, so beware.
porsche986spyder is offline   Reply With Quote
Old 01-11-2008, 04:32 AM   #3
http://www.renntech.org/forums/index.php?showtopic=12805
Tool Pants is offline   Reply With Quote
Old 01-18-2008, 01:57 PM   #4
I have done the swap, its very straightforward, however, I STILL have fuel gauge inaccuracies.
Patrick
Old 01-19-2008, 10:15 AM   #5
Did it
Still not sure about the fuel gauge. Have not driven that many miles since...
Be sure to check the link from Toolpants' post. That will answer most of your questions.
'01 S with '04 C4S cluster.
Jake
http://www.jazmine.com/images/avatar.jpg
My FB has lots of pics
01 Speed Yellow Boxster S
- Tip
- PSE
- C4S Cluster with new style OBC
- 18" with 7mm rear spacers
- Litronics
- Fully de-ambered
- LED taillights
- Aluminium Pedals
- Integrated Garage Door Opener
- 986 emblem
- Yellow brake calipers with Brembo stickers
- Yellow center console
- Aerokit II wing & trunklid
- Eibach Pro springs
In memoriam: Black 935 Street
LowFlyR is offline   Reply With Quote
Old 01-19-2008, 04:50 PM   #6
Thumper's Avatar
I did it and have had no issues with the fuel gauge. I've put two different clusters in mine and both read correctly. The key is to find one from a C2 Carrera, a Cabriolet if at all possible (that way your top open light will work upon installation). It's a straight forward swap and if you can pick up the Carrera gauge pod with the cluster, it makes it even easier. (Your Boxster pod will work with some trimming.) Keep in mind that if your Boxster is a 2000 or earlier, you will need the cluster from a 2001 and earlier C2 Carrera, if it is a 2001 or newer Boxster, you will need the cluster from a 2002 to 2004 C2 Carrera. There is also the issue with changing the mileage of the donor cluster to match the mileage of your Boxster, which isn't cheap to do (see the thread ToolPants gave you the link for). The dot matrix display rocks!
I know, I need to vacuum the carpet.
Thumper is offline   Reply With Quote
Old 01-19-2008, 06:19 PM   #7
Two clusters and both on tiptronic Boxsters. Somehow that just seems statistically unlikely, lol.
-David
1995 Silverado V8 - Green/Tan (FOR SALE)
2000 Boxster S - Ocean Blue/Graphite Grey
2002 GSXR750 - Blue/White
http://www.darkoven.com/sig.jpg
David N. is offline   Reply With Quote
