Old 09-19-2004, 12:08 PM   #1
Send a message via AIM to Subanez
New or Old Mass Air Sensor?
Is there an easy way to tell if your Mass Air Sensor is the old style or the new style, for a 2000 Boxster? That is to say, whether or not I'd need the "E-accelerator" version or not.
I suppose I could call the dealership and have them look it up for me, but I avoid the dealership at all costs (because they "cost" way too much, usually).
"Action is Eloquence." -Shakespeare
"I ran until my muscles burned and my veins pumped battery acid. And then I ran some more." -Fight Club
Subanez is offline   Reply With Quote
Old 09-19-2004, 12:23 PM   #2
http://www.renntech.org/forums/index.php?showtopic=659&st=0
All you need to know is above.
E-gas started in 2000 and there have been 3 sensors used. 1997-1999 are not e-gas and they use a different sensor.
The first e-gas sensor had a flat bottom. The second started in January 31, 2000 had has a hooked bottom. The third is a replacement for the second as the second was discontinued.
You cannot swap between the first and third versions unless the DME is reprogramed.
Old 09-19-2004, 12:36 PM   #3
Thanks a lot!
