Old 11-14-2007, 06:41 AM   #1
Windows stuck on a 2000S
After a really hard rain the both window switches would not work. The swith worked a couple of times but then craped out. I've searched and know about the regulator, but I dont think that is the problem. If I open the door the both windows would come down 1/2". Also I unlocked the top and the windows came down the normal amount (6" or so). But now they will not go back up
Any help?
ataim is offline   Reply With Quote
Old 11-19-2007, 10:56 AM   #2
I have had an issue if you take the top down and then put it back up again the windows would not go back up. what I had to do is unlatch the top and then latch it again. Some where there is a sensor that tells if the latch is secure. I have seen this happen a few times, but always fixes it's self if you re-latch it.
97 triptonic
nightscout is offline   Reply With Quote
