Old 10-24-2007, 09:36 PM   #1
Is cylinders 1-3 on the driver's or passenger's side?
I've searched but can't find an answer, which side is cylinders 1-3?
I'm getting code P1119 on my OBD2 scanner, I read about switching the O2 sensors to confirm if it is a faulty sensor that's causing the CEL. Should I expect a P1115 or a P1117 code after I switch between the left and right side pre-cat sensors?
Thanks.
tracke30m3 is offline   Reply With Quote
Old 10-24-2007, 10:40 PM   #2
That is bank 1 on the passenger side for a LHD.
Tool Pants is offline   Reply With Quote
Old 10-25-2007, 11:09 AM   #3
Thanks, so bank 1 aka cylinders 1-3 is on passenger side on a LHD car and bank 2 aka cylinders 4-6 is (obviously) on the driver's side?
So CEL code P1119 refers to the pre-cat 02 sensor on the driver's side?
Thanks.
