Old 09-30-2007, 03:03 PM   #1
Question Turn signal problem after de-amber.
I've searched but found no answers, so if I'm missing the thread on this subject, I apologize.
I took the amber out of my Litronics yesterday (2003 S).
Turn signal on the driver's side works fine. Front passenger turn signal does not work at all (bulb IS FINE) rear passenger turn signal blinks very rapidly.
With the hazards, Driver's side works fine, passenger side rear normal (not rapid) passenger side front does nothing.
Any ideas? Fuse? Relay? Did I break something?
"Life doesn't have to be hard"
ericweller is offline   Reply With Quote
Old 09-30-2007, 04:48 PM   #2
i know you said it's not the bulb, but it sure sounds like the bulb. just for the heck of it, have you tried a different bulb? or maybe one of the wires on the connector for the bulb has a problem?
humara is offline   Reply With Quote
Old 09-30-2007, 05:31 PM   #3
Yeah, I tried the bulb from the driver's side, tried the passenger side bulb in the driver's side, both bulbs work, just not when installed on the passenger side.
I took the wires off and looked at them, they look ok, seem tight and connected.
I'll try pulling the whole assembly and putting it on the driver's side.
