-   -   Convert the real fog lamps and the brake light position into a running light (http://986forum.com/forums/performance-technical-chat/13055-convert-real-fog-lamps-brake-light-position-into-running-light.html)
Corleone 09-06-2007 08:40 AM
Hi to everyone!
I´m new to the 986 forum.
Right from the start I have a question.
I want to transmorgrify the tail lights of my 2001 Boxster S a little bit more 987-like by converting the fog light and the brake light position into a running light.
To maintain the fog and brake light function you could replace the P21W into a P21/5W bulb.
If you remove the upper pin with a file, the new bulb will fit into the existing frame.
But how do you proceed?
Has anyone already done this conversions?
Cheers, Stephen
Corleone 09-09-2007 10:53 PM
Any ideas?
Gary in BR 09-10-2007 08:43 AM
I don't know of any one who has done that one. I do know it is possible to make the rear fog lights light when the brakes are pressed.
There are led tail lights that have a 987ish look to them, they are availible on some auction site.
Good luck.
