Old 09-04-2007, 02:57 PM   #1
Rear suspension noise
I have a noise coming from my rear suspension that is getting worse. It sounds like a clunk or knocking when I go over a series of bumps or single bump. If you are driving it sounds like it is coming from the rear passenger side. If you are riding in the passenger seat it sounds like it is coming from the driver side rear. Acceleration does not cause the sound, only bumps in the road. The sound is the same with the top up or down. My local mechanic and I ckecked the rear struts and sway bars and everything seems to be tight. Does anybody have a clue what it might be?
2002 Boxster
Rev Den is offline   Reply With Quote
Old 09-04-2007, 03:14 PM   #2
One possible thing is that it could be your shock. The sound you are describing could expain it however it usually always sound like it is coming from the same side and does not move around. It is highly unlikely that both shocks went at the same time. Did you look to see if any of the fluid has leaked out of the shock assembly? It will usually be apparent on the inside fender or right on the shock itself. When a shock loses it's fluid it can make a sound exactly like what you saying but whatever it is it sounds like it is related directly to the suspension or something attached to it.
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
der Geist is offline   Reply With Quote
Old 09-04-2007, 08:07 PM   #3
I checked again and there is no evidence of any shock leakage. After some more driving I think the sound is only coming from the right rear side. The shock seems to still have good compression when you press down on the rear end. Any other possibilities?
Old 10-17-2007, 04:28 PM   #4
Send a message via MSN to faheemf1
It is possibly your rear track arms. Have you had them checked?
faheemf1 is offline   Reply With Quote
Old 10-17-2007, 06:08 PM   #5
My car makes the same noise. I had it checked out and mechanic cannot find anything wrong. I heard a similar noise from my 2000 Z3 when it was brand new.
I thought maybe it was just characteristic of convertibles.
To me, it sounds like it is coming from an area between engine and rear seats, possibly low to ground, but I cannot distinguish which side if any.
Richard Griffin
Atlanta GA
2001 blk/tan Boxster 18" turbo twist wheels
2003 gray/tan Navigator
rgriffin is offline   Reply With Quote
Old 10-18-2007, 07:15 AM   #6
Count me in as well, it's on the driver's side, behind my left shoulder, but it's hard to tell how far up/down. I had my alignment guy look at it, and he couldn't find anything.
It will pop when it's being jacked up off the ground, and will pop either when it's let back down, or when you sit in it after it's back off the jack. When driving, it will occasionally pop when cornering hard right (and loading up the suspension on that side), and will especially do it if there's a bump in the corner that loads and unloads the suspension.
My noise sounds like someone lightly tapped a solid part of the frame/suspension with a ball pein hammer. Like maybe a bolt is loose, and whatever it's holding can slide around under it's head? But the weight of the car normally keeps it from sliding.
A bad strut (shock) is a good idea. I've looked over the bottom, I'll have to take a closer look at the top of the strut and it's mounting area. I guess it could be internal as well. It's not leaking on mine.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
Old 10-18-2007, 07:51 AM   #7
When my rear end started to make that noise it was the rear-track arm control arms. There is really no way of checking them cause the play that the bearing cartridge develops is as thin as a hair but can cause ALOT of clunking and chattering from the rear end when going over bumps.
DIY - Replace Rear Upper Control Arms (Track Arms)
Che @ delubozparts Rear Track Arms GB $249.99 Shipped
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 10-18-2007, 08:03 AM   #8
A bad shock will almost always show some sign of leakage from the cylinder. When driving with the top down it will be very clear that the sound is coming from the top of the shock tower. Maybe you could put a lubricant on the moving parts of the track arms one at a time to isolate the problem. When the noise stops you have found the bad part. Not foolproof but it may be your only choice of diagnosing this if the mechanics can't be certain.
'03 Midnight Blue
'69 911 Black
Cancer Survivor
Old 10-18-2007, 08:08 AM   #9
Too hard to put lube on the track arm that I'm talking about cause its got a rubber flexible boot on both sides of the cartridge. Chances are that it is his track arm control arm that I'm speaking of cause his symptoms are 100% identical to the symptoms i had experienced when my track arms failed.
Carlos J Cazares
Old 10-18-2007, 08:21 AM   #10
If the symptoms are 100% then I guess there is not much point to doing anything other than switching them out. Should be a nice project for the weekend.
'03 Midnight Blue
'69 911 Black
Cancer Survivor
Old 10-18-2007, 08:39 AM   #11
Yeah, my front track arms should be arriving today so that will take care of the noise i get from the front as well.
Carlos J Cazares
Old 10-18-2007, 04:14 PM   #12
I notice a sort of muffled rattle or knocking over bumps when the car is cold (as in, just started it up and driving a few miles), but it doesn't sound metallic. It almost sounds to me like it could be coming from the engine cover, but I haven't tried to locate exactly what it is. It seems like an impossible task.
2000 Guards Red Boxster
There is no substitute.
Padawan is offline   Reply With Quote
Old 10-18-2007, 09:10 PM   #13
Hmmm, not typical of a rear track arm failure, Usually the track arm will make more sound as the day and bearing cartridge warm up and is quieter when cold.... my thought is that nylon bushing within the cartridge softens up when temps around it increases... remember the exhaust manifolds are very close to the bearing cartridge.
Carlos J Cazares
Old 03-27-2008, 02:39 PM   #14
Smile
I finally replaced my right rear control arm and the noise is gone! Thanks for the advice.
