-   -   windows going down on their own (http://986forum.com/forums/performance-technical-chat/12797-windows-going-down-their-own.html)
boxster 08-21-2007 04:57 AM
hi, i have a 986 and recently i noticed that when the top is down and im driving with the windows up, they start going down slowly on their own. this only happens when im driving. could it be when i hit a bump in the street or a pothole that this effects them and start to move down?
BoxsterBob - CA 08-21-2007 07:22 AM
Quite possibly the microswitch in the top latch setup. Do the windows go down ~2 inches, just like when you pull the top latch prior to opening? If so it's likely the microswitch. You may want to spray some compressed air in the opening to remove dust that accumulates on the contacts.
The easiest solution is to put the windows down when the top is down. :cheers:
boxster 08-22-2007 04:12 AM
yes thats what happens, they go down about two inches just like when you want to open the roof. i just bought a can on compressed air, will try your suggestion thanks. well if the problem remains, i guess thats the best thing to do, just roll the windows all the way down, thanks!
BoxsterBob - CA 08-22-2007 06:47 AM
You can replace the microswitch. It's an inexpensive part and can be done yourself if cleaning the contacts doesn't remedy this, however, the switch rarely fails completely, so the problem is intermittent. Generally cycling through the top up / top down cycle a few times will eliminate the problem, at least temporarily.
I've had the microswitch in the hand brake act up a few times in 5 years, a few spirited up / down cycles brings it back on line. Good luck.
Are you in Malta, NY or the Island of Malta?
boxster 09-11-2007 01:49 AM
malta
I live on the island of malta. its a teeny weenyisland of just 120 square miles!!
