Old 08-01-2007, 02:02 PM   #1
Send a message via MSN to CJ_Boxster
Should i have no high end torque after disconnecting battery?
Well i disconnected my battery for more than 15 minutes before diving nose deep into a DIY repair for my horn. When i put everything back together and let the car idle for a bit, set my time and entered the radio code. I went for a drive and noticed that i have no pull/torque past 4000 RPMs. Is this normal, should the torque come back after a certain amount of miles? I drove more than 70 miles already and still not pull/torque past 4000 RPM range. The torque feels way to linear and flat, I feel nearly no g's when accelerating past 4000 rpm's.
I did however forget that i left ignition switch in the ON position when i was working in the 2 torx screws behind the steering wheel, to keep the steering lock disabled, Then reconnected the battery with the ignition in the ON position by accident... Could that have jacked something up?
Right now, i just disconnected the battery, im going to let it sit for maybe 30-40 minutes and hopefully that clears anything stuff up.
UPDATE: after letting it sit for 1hr with the battery disconnected, no change, still no torque pasted 4k rpm's. The sluggishness feels alot like when my MAF needed to be cleaned.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
