Old 05-30-2007, 12:48 PM   #1
Error Code 1126
Does anyone knows what the generic error code 1126 (obtained on a Snap-On reader) corresponds to in the Porsche world? Does it has to do with the O2 sensors?
Thanks.
Eleung is online now   Reply With Quote
Old 05-30-2007, 12:57 PM   #2
Send a message via MSN to CJ_Boxster
Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Rich Threshold
Not sure if it means the O2 is bad but there a many possibilities like a bad MAF
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 06-07-2007, 04:44 PM   #3
1126 hope this helps
Motronic 5.2.2 Current Fault Codes P1126 Porsche fault code 35 - Oxygen sensing range 1 Cylinder (4-6) P1124 Porsche fault code 27 - Oxygen sensing range 1 Cylinder (1-3) P0446 Porsche fault code 95 - Shutoff valve activated charcoal filter (function) below limit value P0410 Porsche fault code 80 - Secondary air injection system Cylinder (1-3) Signal implausible P1411 Porsche fault code 208 - Secondary air injection system Cylinder (4-6) Signal implausible
rpagan is offline   Reply With Quote
Old 07-04-2007, 03:26 PM   #4
I replaced the Air Mass Sensor and it seems to have solved the problem.
Thanks to rpagan and CJ_Boxster for your help.
