Old 05-23-2007, 11:13 AM   #1
Send a message via MSN to CJ_Boxster
Question Seat Belt recepticle part numbers
What is the most updated seat belt recepticle part number?
Im pulling a code 41(driverside seat belt unplugged) error, tried cleaning and the airbag light stayed off for 3 hours then came back. Need some guidence with this issue.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 05-25-2007, 03:16 PM   #2
Couper1's Avatar
CJ,
I think there is a recall on those seat beat recepticals. Might want to check with your dealer to see if you're still under a warranty. even if you're not they may offer some sort of fix because it's a safety issue. Did you try spraying the contact cleaner in there then blowing it out with a compressor. I did that over a year ago and it's been fine ever since. Hope this helps.
Couper1 is offline   Reply With Quote
