Old 05-15-2007, 07:54 PM   #1
Flashing light on temperature gauge
I just changed the water pump but the Temp. gauge light is flashing...need help
986prospect is offline   Reply With Quote
Old 05-19-2007, 05:10 AM   #2
Couper1's Avatar
I also had to replace my water pump. I had the coolant flushed and refilled at the same time. If your temp light is flashing it means you have a low coolant level. I suggest you have the coolant flushed and refilled. It is a tricky job but well worth the peace of mind.
Couper1 is offline   Reply With Quote
Old 05-19-2007, 08:17 AM   #3
Here is an article on replacing the coolant tank. Scroll down to the end and it gives a good explanation on how to bleed the coolant system to get the air out.
E
http://www.dietersmotorsports.com/tech/tech9-03-2003.htm
ethand is offline   Reply With Quote
