Old 05-26-2007, 08:51 AM   #9
The camber plates that I have seen would most certainly raise the ride height of your car. I am not sure if they are all like that. If they are you would probably want the lowering springs just to get your ride back to normal. Except for track or autocross where you would probably want it lower than normal. Either way you sound like you would be spending almost as much for camber plates and lowering springs as you would for a set of coilovers. If you are going to track or autocross I would highly suggest you spend the few extra $$ and get the coilovers. The ride is a bit stiffer but worth it. Two of the nicest thing about the coilovers I have found is that you can adjust the stiffness in a few seconds and the ride height in about a half hour.
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
der Geist is offline   Reply With Quote
