Old 05-10-2007, 08:53 PM   #1
top problems!
man it never fails, fix something (leaking cam cover gaskets) and then BAM something else breaks...
so I open the top for a ride, get home to close it and it closes normally but it does not quite make it all the way closed, it seems closed but the light is still on saying it is not completely closed....
so I push the button to close it all the way and I hear very wicked griding noises and the top doesn't budge.
It wont open, close completely, or move an inch. I can hear the motors trying to run, very faintly, but no movement.
anybody have something like this? I know the relay and fuses are good, cause I can hear the motors, but just barely.
Everything else electrical seems to work just dandy.
Arctic Silver 2000 Boxster 3.4l w/Sport Design Package
Supersprint Boxster S Headers/Cats/Muffler
AASCO Lt. Wt FLywheel
Evo Intake
Partial Carbon Interior
Black Leather Sport seats
M030 Sway Bars
Litronics w/ Clear Corners
Boxster S brakes
B&M Short Shifter
PnP rear Speakers + Amp
pecivil is offline   Reply With Quote
Old 05-11-2007, 02:24 AM   #2
top problems
its probably the drive cables. If you look inside top compartment, you can see a red (driver side plastic fitting, white on right side. pop them off and operate it manually. 862-222-4618
Peter Serbanica is offline   Reply With Quote
