Old 05-09-2007, 03:38 PM   #1
Movement/play in Shifter
How much play is allowable in a stock shifter setup, Currently i have nearly a half inch of play (side to side) in my shifter. Is that too much play?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 05-09-2007, 04:07 PM   #2
Stop playing with your shifter. You'll go blind.
http://i84.photobucket.com/albums/k2...izzlysmall.jpg
'97 986
Cheating Death on 19" Wheels
...no catastrophic engine failure ...yet
Grizzly is offline   Reply With Quote
Old 05-09-2007, 04:10 PM   #3
Havent you ever heard the saying "If you dont use it, you lose it."???
Carlos J Cazares
Old 05-09-2007, 07:15 PM   #4
Who said that? I can't see you.
'97 986
Old 05-09-2007, 08:55 PM   #5
why don't you just PM MN boxster ??
super66 is offline   Reply With Quote
Old 05-09-2007, 09:00 PM   #6
...Ignoring yoooooouuuuuuu...
'97 986
Old 05-10-2007, 06:38 AM   #7
I already tried that lol jk
Carlos J Cazares
Old 05-09-2007, 09:06 PM   #8
Measured where--at the very tip of the shift knob? At the base? What shift knob? Half-inch of play to each side or total from side to side?
With some assumptions about what you really meant to ask, I can say that you're not describing a lot of play. Considering this is a cable actuation setup, I wouldn't stress about it.
2005 Seal Grey Boxster S
987 Amberectomy
eslai is offline   Reply With Quote
Old 05-10-2007, 06:43 AM   #9
I measure from the tip of the shift knob, i have the 2-tone silver ball type porsche shift knob. Its half an inch of total play in neutral and about 2/3rds that amount of play while in gear. Would you say that is still within spec.
I was wondering cause i was getting frequent 2nd gear grinding UNTIL i decided to hold the shifter firmly to the left as i shift into 2nd rather than semi-firmly and i thought that might be an indication of slack in the lines or play in the shifter assembly.
Carlos J Cazares
