Old 04-27-2007, 08:15 AM   #1
Brake Fluid questions
I searched the forum a little but just don't have time today to really dig into it, so if someone can tell me what I need so I can go to Autozone and get some, that would be great.
Hans did a fluid change on my brake lines when he replaced my pads last year. He used Porsche dot 4 brake fluid.
I want to replace the brake fluid tomorrow morning at a buddy's house and I want to make sure I:
a) Buy enough to get the job done
b) Buy a compatible brake fluid (is the Porsche brand synthetic or mineral?)
A quick reply on how much I need to bleed all four calipers and a compatible brand with what's in there now (Porsche fluid) would be great!
Old 04-27-2007, 08:55 AM   #2
You don't need very much to flush the system. I did some measurements last time I did mine and though I bought 32 fluid ounces I think that was excessive. You only need to flush about four ounces out of each rear caliper (be sure to do both bleed screws) and two out of each front plus another four for the clutch.
I have used Castrol GT4 LMA and Valvoline, both DOT4 fluids, to flush brakes. The fancy fluids are great, but unless you're tracking the car it's of little consequence - you just want a good fluid that does not absorb moisture well. I do it yearly (IMO, the longest interval you should run brake fluid). A Motive power bleeder makes the job much more pleasurable.
John
John V is offline   Reply With Quote
Old 04-27-2007, 10:25 AM   #3
Thanks!
Old 04-27-2007, 03:42 PM   #4
Randall:
Don't forget to flush out the clutch while you are at it. Otherwise that fluid will eventually make it's way back into the system and mix. You should look into a Motive Power Bleeder. Makes it a one man job. Like many others I switch back and forth from the ATE blue to ATE gold. This way you can see when the old is out.
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
der Geist is offline   Reply With Quote
Old 04-27-2007, 04:48 PM   #5
IIRC, DOT 5 is silicone fluid. All others should be "mineral".
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
racer_d is offline   Reply With Quote
Old 04-27-2007, 05:28 PM   #6
Hi,
FYI - DOT 5 is a Silicone based Fluid, while DOT 3 & 4 are Hydraulic Fluids the primary component of which is Polyalkylene Glycol Ether, a synthetic, but often mixed with a mineral oil base. DOT 5.1 is also a Polyalkylene Glycol Ether Fluid, but about half the viscosity of DOT 3, 4, and 5. It was designed specifically for Winter or Cold Climate use, though most European Cars are filled with DOT 5.1 at the Factory. DOT 2 is Castor Oil and used only in Antiques and Collectables because of it's viscosity and friendliness to the Seals, etc. It does not meet the specs of a modern ABS System.
DOT 5 was developed by the US Military which used it since 1982. It has a very high Boiling Point. But, the problem with Silicone is that unlike the Glycol based fluids, it does not mix with water. But, water still invades the system, and since it's specific gravity if higher than that of Silicone, it will migrate to the lowest point in the Brake System, usually the Calipers where it can be compressed into a steam bubble causing Fade, even though the Fluid itself hasn't reached it's Boiling Point.
Also, this water collecting in the Calipers accelerates corrosion and breakdown of the Piston Seals. Despite superior performance, increased maintenance costs from the use of DOT 5 has caused the Military to revert back to Glycol based fluids.
But, Racing, where maintenance costs are not really a factor, continues to use DOT 5 for it's performance. But, unless you are going to swap fluid every 6 mos., DOT 5 should be avoided.
I use ATE Typ 200 (Gold) and Super Blue in my Boxster. But use Castrol LMA (Low Moisture Accumulation) in both my Esprit and 240Z because of the Rubber (as opposed to Butyl) Seals and it is quite good as well as being a couple bucks cheaper.
Personally, I always blow at least a quart through the system to aid in removing contaminates and particulates which come from the breakdown of seals and other parts.
Just be sure to bleed in the proper order. Start with the wheel furthest from the Master Cylinder and work your way backwards to it. Also, be sure to bleed the outboard valve on the Caliper last (the Boxster has 2 Bleed Valves per Caliper). This way, any air which could migrate from the inboard Bleeder to the outer set of pistons is extracted.
As mentioned, the Motive Bleeder works best and is really necessary on an ABS system. Just be sure not to exceed 20PSI to insure that you don't blow the Seals on a used Master Cylinder. This takes a little more time, but is cheap insurance. Good Luck! ...
Happy Motoring!... Jim'99
