Old 03-03-2007, 10:52 PM   #1
996 Gauge Cluster into Boxster S
I am told the 996 guage cluster is a plug in swap into a boxster. How true is this? Are there already senders in the car to feed the oil pressure and voltage gauges? Does Porsche keep the mileage in the cluster or in the ECU somewhere (i.e. if I get a cluster out of a 20k wrecked 996 will my box show 20k on the clock, or the real mileage)?
Patrick
Old 03-03-2007, 11:11 PM   #2
Send a message via AIM to djomlas
use a search here, and also i would recomend using a search button on renntech.org there was a discussion there on that
good luck
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
Old 03-04-2007, 10:28 AM   #3
Porscheectomy
Here you go.
http://www.renntech.org/forums/index.php?showtopic=12805
If you haven't joined renntech yet, you should.
Old 03-04-2007, 11:41 PM   #4
Fantastic-
Thanks for the link.
Patrick
Old 03-06-2007, 09:00 PM   #5
Just found a 996 cluster out of a C2 so will be doing this mod sometime in the next few weeks. Looks pretty straight forward aside from running the wire to the new oil pressure sender.
Patrick
Old 03-07-2007, 06:53 AM   #6
Thumper's Avatar
I'm wondering if you can just add the extra two gauges to the 986 cluster? I do realize that the oil sending unit still would need to be replaced and an additional wire added so that is is functional.
Thumper is offline   Reply With Quote
