Old 04-20-2007, 10:41 AM   #1
Angry Spark plugs
Forgive me, I have searched and can not seem to find a simple DYI for SP removale. Read that tires must come off, anything else or is that all there is to it?
Frank Patrick is offline   Reply With Quote
Old 04-20-2007, 02:00 PM   #2
You don't actually need to pull the Tires.
Raise Car securely.
Using a 6mm (?) Hex Bit (or Allen Wrench), remove the 2 screws holding the CoilPak to the Valve Cover. Twist slightly while extracting the CoilPak (if inexperienced, do one CoilPak at a time to avoid mixing them up).
Using a 5/8" Long Spark Plug Socket (or a normal one with extention), remove old Plug.
Install new Plug and torque it to 26 ft. lbs.
Re-insert CoilPak and push it til it clicks
Reattach screws to Coil Pak and torque to 6-7 ft.lbs.
It's also a good idea to run your finger in the hole to insure that there is no Oil on it indicating a leaky Spark Plug Tube 'O' ring - replace as necessary.
Also, stick with OEM Plugs, there is no advantage, but a possible disadvantage, to using Aftermarket Plugs. Hope this helps...
Happy Motoring!... Jim'99
Old 04-20-2007, 02:16 PM   #3
Perfectlap's Avatar
After reading this I'm starting to second guess the point of having the dealer do my spark plugs as part of my 30K service.
I still need an oil change and brake flush and a once over inspection but I hardly think it merits the $900 fee. I'm thinking I'll do the air/pollen filter and spark plugs me self. The only reason I was leaning toward the dealer was to have the records which so far indicate that only Porsche mechanics have touched my car.
what's a good source for OEM plugs?
Old 04-20-2007, 04:12 PM   #4
Call NAPA, they stock em and no S/H. I wouldn't put much stock in only Porsche Mechanics wrenching on the Car. Bye and Large, they're OK, but they have their share of Knuckleheads as well. This is so easy, it doesn't pay to have someone do it - took me 20 min. I think and I know it's done right! Good Luck!...
Old 04-21-2007, 06:51 PM   #5
deliriousga's Avatar
What Jim said (especially about sticking with the OEM plugs) but the hex bit is 5mm (to answer the question marks). John linked my site and I show how to replace them with the wheels off but you don't have to take the wheels off in order to change the plugs. I do a brake inspection at the same time so it's just easier for a fat guy with fat hands to reach in through the wheel well.
I have the OEM part number for the Bosch plugs on my site if you want to look around and find them online.
1966 Wife White/Brown Top
Old 04-21-2007, 07:03 PM   #6
When I did mine five clicked and one no matter how many times I tried to re-insert it wouldn't make(or maybe I couldn't hear) the clicking sound. If the CoilPak wasn't installed correctly it wouldn't it have triggered a CEL?
Old 04-23-2007, 11:03 AM   #7
Definitely remove the tire. It makes it much easier to see what you're doing - you don't have to phyically get under the car if the tires are off.
John V is offline   Reply With Quote
Old 04-23-2007, 12:14 PM   #8
Smile Thank you-great advise
Thanks to you folks, job was done in a falsh, great info, I feel like a dunce asking the question now. I used the (7) heat range plugs, no anti seeze, and found one damaged 0 ring on one of the tubes. Not sure what my dealer would have charged, but I don't think it would have been cheap. Thanks again!
Old 04-23-2007, 01:31 PM   #9
Perfectlap's Avatar
what brand of anti-seize should be used?
Old 04-23-2007, 02:01 PM   #10
got it
did not use ant-seize or seeze, although the seeze is much cheaper
Old 04-23-2007, 02:53 PM   #11
This has been debated. No anti-seize s/b used IMHO, though there were opposite views proferred. Porsche does not use it, nor does the Dealer Service Manual recommend it...
Old 04-23-2007, 07:15 PM   #12
One thing I noticed when using anti-seize is my radio reception goes down and interference goes up. It happened to me on both P-cars so I don't think it was a coincidence.
Old 04-24-2007, 02:48 PM   #13
Perfectlap's Avatar
how about cleaning in there with simple green?
Old 04-24-2007, 11:13 PM   #14
Cleaning where? The Sparkplug Tubes? No! No! you don't want any condensation building up in there...
Old 04-24-2007, 11:20 PM   #15
Interesting observation. Did you use normal Anti-Seize or Hi-Temp Anti-Seize?
OEM Plugs are Resistor Plugs designed to reduce Radio Interference. A Normal Anti-Seize would tend to work as an Insulator while a Hi-Temp (with it's high metallic content) would work as a Conductor, either could interfere with this property of the Plugs...
Old 04-25-2007, 12:57 AM   #16
fab
fab's Avatar
After reading Jim's instructions I'm AMAZED. Last week I was at the STEALERSHIP for an alignment and asked how many hours of labor is needed to change sparkplugs. DRUM roll.......2 hours. I kindly passed...
00 Boxster Tip Blk/Blk
100% de-ambered
painted center console
painted bumperettes
autoband paint protection
wheel caps & colored crests
door sills
Valentine One
fab is offline   Reply With Quote
Old 04-25-2007, 01:08 AM   #17
It's an easy D.I.Y. , just follow Jim's(MNBoxster's) instructions and you can do it in 1-1.5 hours tops.
Old 04-25-2007, 01:34 AM   #18
Yea, if you're tapping a cold one in-between each Plug. Takes me 20 min. tops.
I label each CoiPak using Masking Tape 1-6 and remove them all at once. Then switch tools and remove all the Plugs at once, then insert all the new Plugs, torqueing each one, then replace the CoilPaks and torque them.
I jack up one side of the car and place a jackstand under it, this allows me to get under the car with a creeper, and I do have a long 5/8" Sparkplug Socket and a Speed Wrench which helps. And I use a Black & Decker cordless Ratchet to remove the CoilPak Screws which helps, but even using ordinary handtools, it should take no more than 30 min...
Old 04-25-2007, 01:39 AM   #19
Hey Jim,
You seem like the kind of guy that believes that there is nothing better than stock. I like that. I don't practice that myself, but I like and respect that a lot. I actually listen to much of what you say before I go and do fool-hardy things to my car. Hehe... No seriously, I appreciate the advice. It keeps me from doing stupid things!
conradtan is offline   Reply With Quote
Old 04-25-2007, 01:42 AM   #20
I swear whenever I start a project I make it a project within a project. I started to change the spark plugs and found the CoilPaks dirty,so I cleaned them,found dirt lodged in other areas around the working area,cleaned those as well. If I didn't clean everything while I was under there it would have taken 30 minutes or so now that I think about it.
