Old 04-14-2007, 05:17 AM   #1
Tyre Preasure Question
I've just replced my standard 16" with 18" and have 245 x 45 on the fron & 285 x 35 on the rear. Any suggestions on preassures?
aussieboxy is offline   Reply With Quote
Old 04-14-2007, 06:18 AM   #2
edevlin's Avatar
On the recommendation of several others on the forum, I have been running higher than the factory suggested pressures to good effect. I think I have settled on 34/39 for front/rear for normal driving, it seems to give better control on the twisties with my PS2's.
Ed
My Car Webpage
2000 2.7L Boxster 102K; TTP intake, headers, high-flow cats; Dansk high-flow muffler; Autothority ECU chip; TechnoTorque 2; Bilstein coilovers; Racing Dynamics strut brace; stress-bar suspension kit; Aasco lightweight flywheel, B&M short shiftkit; 18" wheels; spare tire delete; OEM GT3 seats; JL audio speakers and subwoofer; Alpine PDX-5/PDX-2 amps; Kenwood DNX8120 CD/DVD/Nav; litronics, deambered
edevlin is offline   Reply With Quote
Old 04-15-2007, 09:25 PM   #3
I agree with running somewhat higher pressures to help handling, though be careful, esp at the rear with overinflating and getting uneven wear.
As to your tire sizes, you are running too high an overall diameter. If you want a 285 rear, it needs to be a 30 series, not 35 series. Most run a 225/40 front, if you wanted a 245 (which is quite wide for the front of these cars) it would need to be a 35 series to have the proper diameter (which would then be a bit too small overall, but is still closer to correct than the 45 series).
Patrick
Old 04-20-2007, 10:09 AM   #4
Question tire pressur over spec?
Since many Boxsters are running on summer spec tires, won,t this overinflation have a negative effect on the tire longevity?
Frank Patrick is offline   Reply With Quote
Old 04-20-2007, 05:48 PM   #5
Track rat
Topless's Avatar
Higher tire pressures within reason tend to wear the tire more towards the center. Boxter tires usually wear at the edges... Inside edge for daily drivers/freeway riders, outside edge for canyon carvers/track hounds. I tend to wear em out on the outside even with max negative camber. A little extra air can be a good thing.
Old 04-20-2007, 06:06 PM   #6
For the stock 225 front, 265 rear on 18's, porsche lists 29psi front and 36psi rear. If you want to dial out some additional understeer, you might try 36 all around.
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
racer_d is offline   Reply With Quote
Old 04-20-2007, 09:13 PM   #7
I have 205/50WR-17 on the front wheels and 255/40ZR on the rear ones. What should be my tire pressure?
clb0099 is offline   Reply With Quote
