Old 10-04-2023, 05:34 AM   #1
Boxster Purchase
As I see, this isn't actually a new topic: I am considering purchasing a Boxster but have some misgivings. I am currently a 2015 Mazda MX-5 Grand Touring owner and have been happy with the car, but would like something a bit more comfortable and have wanted a Boxster for a long time. I have seen several polls that rate the Boxster as highly expensive to maintain with relatively low reliability. I do the usual maintenance, such as oil changes, brake replacements, belt replacements, etc.,on my cars myself and would hope to continue to do so with a Boxster, not only to save money but because I enjoy it. So, is a Boxster relatively easy to work on oneself? Are they expensive to maintain and should repair above usual maintenance be expected, and if so, are there common problems that occur? My MX-5 has been virtually problem free for the 8 years I have owned it, and I have a 2006 Chrysler Sebring convertible that I have had since new that I've done a lot of repair work on during its 277,000 plus miles without needing to take it in for expensive shop work. Can I expect the same from a Boxster? Any insight or suggestions from actual owners will be welcomed.
Steve Y is offline   Reply With Quote
Old 10-10-2023, 11:50 AM   #2
From what you have described on what you can do on your own, you would not have any trouble maintaining a Boxster. The main items that are hard to fix/replace are the IMS bearing and the coolant overflow tank. If you can find one that has had that work done, then you should have a good experience.
redpepperracing is offline   Reply With Quote
Old 10-13-2023, 05:00 AM   #3
PLP
PLP's Avatar
Indeed OEM parts for Boxster are more expensive that other comparable cars. You can always go with aftermarket.
Reliability?
I am not sure about this one.
I had mine for almost 3 years and it never failed me. I did not put many miles as I was doing some projects on it.
Most repairs are DIY type. Some need more skills than others.
However, after all, it is just a car.
Current rides: 2003 Porsche Boxster MT (me), 2019 Bolt LT (me), 2015 Audi Q5 (wife), 2008 VW Rabbit (2.5 inline 5, MT, well, for kid... but you now, it is the 5 straight)
Previous: 2014 Fiat 500e, 2016 KIA Forte5 SX, 2016 Fiat 500X, and some old days: Trabant, Fiat 126p...
PLP is online now   Reply With Quote
HTML code is Off
