Old 03-20-2023, 05:17 PM   #1
2003 Boxster S - IMS
Hello!
Bought my car in Nov.2022 with 53k miles. As I live in Minnesota it has been winterized.
Looking to upgrade my IMS bearing.
I know the most reputable definitive solution available is from LN Engineering with DOF. Very expensive - $1,900.
I am in between two alternatives:
a) Universal single row ball bearing (steel) from Pelican at $190.
Similar to the original but with upgraded seals.
Pelican recommends replacing it at every clutch change, approx. 40k miles.
b) Double row, ceramics ball bearings (European Width) from LN Engineering at $949.
Holds higher loads and offers better wear resistance due to ceramics balls.
LNE recommends replacing it at every 75k miles or 6 years.
Talking to experienced Porsche technicians from independent shops, they favor the ceramics. I've read about a fellow Boxster owner who had the ceramic bearing failing after 30k miles of being replaced. The ceramics balls worn out the inner and outer races (steel)
Pls share your experience.
leandrog is offline   Reply With Quote
Old 03-20-2023, 06:28 PM   #2
Search is your friend; this has been covered ad nauseum, and I install them for a living.
Old 03-21-2023, 04:16 AM   #3
"50 Years of 550 Spyder"
10/10ths's Avatar
Easy….
….Install the “IMS Solution” from LN Engineering.
Old 03-21-2023, 08:16 AM   #4
Originally Posted by leandrog View Post
Hello!
I can't comment on the IMS issue....
But why in the world would you need to replace your clutch every 40K miles?????
If that is truly the case then I would say you don't know how to use a clutch.
Old 03-21-2023, 12:48 PM   #5
Yup, kinda what I was thinkin'
Frodo is online now   Reply With Quote
HTML code is Off
