-   New Member Introductions (http://986forum.com/forums/new-member-introductions/)
-   -   Manual Crank Shaft Turning (http://986forum.com/forums/new-member-introductions/82854-manual-crank-shaft-turning.html)
1947verns 01-17-2023 12:48 PM
My 1998 Boxster is burning coolant and in the process of removing the sparkplugs, coolant drained from the number 6 cylinder. I would like to take a endoscope video of the cylinder fully open to determine if the block or cylinder head is cracked. I need to rotate the crankshaft to the fully open position on this cylinder, but the crankshaft is not turning when a socket wrench is applied to the crankshaft pulley. How can the crankshaft pulley be freed up? Please advise. Thanks.
JFP in PA 01-17-2023 12:59 PM
Originally Posted by 1947verns (Post 650482)
My 1998 Boxster is burning coolant and in the process of removing the sparkplugs, coolant drained from the number 6 cylinder. I would like to take a endoscope video of the cylinder fully open to determine if the block or cylinder head is cracked. I need to rotate the crank shaft to the fully open position on this cylinder, but the crank shaft is not turning when a socket wrench is applied to the crank shaft. How can the crank shaft be freed up? Please advise. Thanks.
By spending a lot of $.
