Old 05-24-2021, 04:33 PM   #1
New owner/member in Texas
Just brought a 1997 Boxster home. Last registered in 2004 and with 34k on the clock. So besides a coolant flush, currently overheating and the water is brown and moldy, oil change, and fresh tires; what else should I be looking at before going a mile in it? I have a 3.4l 996 donor motor that I’m going to rebuild.
southtxpilot is offline   Reply With Quote
Old 05-24-2021, 06:57 PM   #2
Congrats on the '97 purchase! Feel free to follow along with my '99 thread- I just purchased it and have been baselining it for the past few months.
https://grassrootsmotorsports.com/forum/grm/new-to-me-986-boxster-1999/182782/page1/
986andmx5 is offline   Reply With Quote
Old 05-25-2021, 08:42 AM   #3
Thanks for the info!
W
Old 05-25-2021, 11:12 AM   #4
BYprodriver's Avatar
Welcome to the forum, You should look into LN Engineering for your engine rebuild, especially with a 3.4L M96 .
Old 05-25-2021, 06:57 PM   #5
You mention overheating. It would be a good idea to remove front bumper and clean radiators.
mtb50 is offline   Reply With Quote
Old 05-28-2021, 04:34 PM   #6
New water pump, thermostat, seals, and belt on order. Obvious signs of antifreeze leak on the bottom of the motor. No water in the oil but coolant was frothy. Gonna check the oil cooler and vacuum test the whole system. Previous owner had a bottle of antifreeze in the trunk. Gonna assume the coolant leak has been ongoing.
How prone to failure is the oil cooler? Internal leaks usually oil to water or water to oil?
Old 05-28-2021, 08:37 PM   #7
911monty's Avatar
The oil cooler can fail. Oil pressure should be 20-50 psi. Water pressure is 16 to 20 psi.
HTML code is Off
