Old 02-27-2018, 03:20 PM   #1
Loud Sreeching Noise in Engine compartment
I was cruising along today and started hearing a loud screeching noise from my engine. It is worse at idle .Doesn't matter if it is stopped or moving. With engine access off it almost sound like it is coming from the transmission instead of belts. No loss of power, coolant temp is fine. Please help!
Stiles13 is offline   Reply With Quote
Old 02-27-2018, 04:15 PM   #2
seningen's Avatar
remove the serpentine belt and see if it stops.
mike@lonestarrpm.com
Old 02-27-2018, 04:25 PM   #3
still plays with cars...
BoxsterSteve's Avatar
AOS maybe?
Six speed 2000 Boxster S
Old 02-27-2018, 05:49 PM   #4
Only a small puff at start up, goes away instantly. No leaking oil or consumption.
Old 02-27-2018, 05:43 PM   #5
What do I check next if it still is screeching? (2001) Boxter 5 speed Tiptronic)
Old 02-27-2018, 05:27 PM   #6
Thanks! Ill give it a shot!
Old 04-06-2018, 01:15 AM   #7
Have you confirmed it's not the ancillary belt?
Can you make & upload a video?
If it's gearbox or FW/clutch then it would be a bearing failed, with catastrophic failure imminent, though I'd expect you would experience loss of drive, and the noise would not be present at idle while stationary.
Bullet-Proof_Biscuit is offline   Reply With Quote
HTML code is Off
