Old 01-07-2018, 01:53 PM   #1
gabedrummin's Avatar
Low Oil Pressure Warning Light
2000 Boxster 3.2 118000 When rpm comes off idle Light goes out. Idle is 700/680. No noise
gabedrummin is offline   Reply With Quote
Old 01-07-2018, 03:43 PM   #2
Either a failing pressure sender or actual low pressure. Stop driving the car until you can test both.
Old 01-07-2018, 04:23 PM   #3
Had it at North Houston Porsche they said they didn't experience a low pressure light come on. But it dose as soon as car comes to a complete stop . Car must be at operating temp . The light comes on for a second then goes out.
Old 01-08-2018, 03:02 AM   #4
But has anyone attached a pressure gauge to determine what the oil pressure really is??????
Old 01-21-2018, 09:17 PM   #5
Low Pressure light ON is the indication of problem in oil pump or oil pressure gauge. It is better to stop the car and turn off the engine
JosephJones is offline   Reply With Quote
Old 02-05-2018, 06:49 PM   #6
Agree with the others - don't drive it until you can do some testing. Low oil pressure at idle could definitely signal a dying oil pump, but you won't know until you're able to get a remote oil pressure gauge attached to read pressure in the system. You'll also need to know what the tolerances are for the factory pump and gauge.
If you're lucky, it's simply a gauge problem...if not, you're looking at mechanical replacement of the oil pump. Don't know how involved that is on these cars, but it's better to figure it out and get things sorted before a more expensive repair comes up!
Please keep everyone posted on what you discover!
flynavyj is offline   Reply With Quote
Old 02-06-2018, 03:56 PM   #7
Put a mechanical gauge on it today 10 psi when motor is hot with 5w-40 oil. What would be the thickest oil I could run .Live in the south west.
HTML code is Off
