'04 986 S Newbie - battery charging/replacement issue please help
Hi Everyone -
I purchased an 04 986 S in late Fall. I was foolishly unaware of what to do to prepare the car for the Winter at that time, and when I went to start it up, the battery was dead. I can't access the hood with my key fob and would like to know the following: - How do i access the hood without the key fob or hood release functioning? - Can I jump start the battery with a Noco GB40 ion portable battery charger or should I use traditional charger cables? - Should I replace the battery? If so, what is the best option? I understand the Moll battery has much to be desired. I live in NY, but may be moving to warmer climate in the near future. - Are there issues I should be aware of if I were to replace the battery myself and/or should I just have it done by a Porsche mechanic? - Finally, I bought a 986 battery tender - do I need to use it everyday? I appreciate you reading my long-winded post and look forward to your timely replies. Thank you very much. Rich |
Welcome,
You have a couple of options: 1) Get a battery charger that can connect to the cigarette lighter, recharge the battery, and then open the trunk. 2) use an external battery - ground the negative lead to the door sill on the drivers side and connect the positive lead to C3 in the fuse box. I hope this helps! |
Replace the battery yourself; Porsche will really lighten your wallet. You should use the battery tender if you won't be starting the car for a week+; no need to use it day in and day out.
There are numerous threads relating to opening the frunk when the battery is dead: try searching the forum. Here's one: http://986forum.com/forums/general-discussions/61089-another-dead-battery-locked-frunk-thread.html |
| All times are GMT -8. The time now is 07:21 AM. |
