Old 09-12-2013, 07:10 PM   #1
03 BOXSTER hard to turn
My boxster start to be tough to turn the steering wheel, what could be the problem, could be low steering fluid? Thanks in advance for your help
carlosnolasco is offline   Reply With Quote
Old 09-13-2013, 05:25 PM   #2
03 boxster hard steeting
Anybody have an answer about the steering on the boxster? Is that hard to turn? If is missing some fluid, could be the problem? Any help to be much appreciated.
Old 09-13-2013, 05:59 PM   #3
Topless's Avatar
Low PS fluid or failed PS pump most likely.
Old 09-13-2013, 06:59 PM   #4
Thanks, Topless. I will check the fluid tomorrow, I am not a mechanic, so how difficult is to check the fluid on it, Thanks again
Old 09-13-2013, 07:33 PM   #5
com3dorm3's Avatar
To check the PS fluid, open your engine compartment and remove the PS reservoir cap.
The inside of the cap will have a stick with marks for cold/hot. I like checking when it's cold and ensure the fluid is at the mark. No more no less.
A quick search yielded this:
- Open the engine compartment
HOW TO: Access Engine Compartment on my Porsche Boxster - GSR Autosport Community
Accessing the Engine
- PS fluid reservoir location (same for 986)
Where to top up Power Steering fluid? - 987-1 Series (Boxster, Boxster S) - RennTech.org Forums
2000 Boxster S
com3dorm3 is offline   Reply With Quote
Old 09-13-2013, 08:03 PM   #6
Thanks com3dorm3, I will check tomorrow and let you know. Thanks again
Old 09-13-2013, 09:30 PM   #7
Topless's Avatar
Lots of good DIY projects with pics here as well.
DIY Projects: Do-it-Yourself Repair and Maintenance for your Porsche
Old 09-14-2013, 11:19 AM   #8
Hi, I put fluid and now the PS pump is doing a noise, that did not happened before. Could be the PS pump is bad. how diffiucult to replace it? Thanks for any reply
Old 10-07-2013, 03:52 PM   #9
jcb986's Avatar
Couple of hours. You might want to replace the serpentine belt since you have to remove it. Recommended at 60k.
Old Hippie Young Heart
HTML code is Off
