Old 02-12-2008, 08:44 AM   #1
Locked Out...Help!
I have a 2000 Boxster which I locked in the garage while away on vacation. When I returned neither of my remote key fobs would unlock the doors. I called a German Autoworks repair shop and they told me the car battery must be dead and the only way to open the doors was to pry off the right headlight cover and look for a cable wire to pull which would unlock the doors. I could then jump start the car.
Has anyone had a similar problem? What do you use and how do you pry the headlight cover off?
Thanks for any and all help.
Stuck in SoCal.
bcary is offline   Reply With Quote
Old 02-12-2008, 09:20 AM   #2
You should be able to go through the inner fender.
Here's a detailed writeup: How to unlock your front hood with no power
Stroked & Blown is offline   Reply With Quote
Old 02-12-2008, 09:21 AM   #3
The emergency release cable should be in the right front fender. You might have to fish around a bit.
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
Old 02-12-2008, 09:41 AM   #4
Send a message via MSN to CJ_Boxster
Dont forget fella's, after so many days sitting idol the cars transponder will shut off to conserve battery power. so you will have to unlock the car with the key in the door, then start the ignition and the transponder will start to work again and receive signal again from your Key fob
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
HTML code is Off
