Old 05-05-2024, 04:03 PM   #1
right turn signal
Hi All
I have a 99 Boxster. My front right turn signal is not working. The bulb is ok and the rear flashes rapidly. The left side works fine. I've taken the headlight assembly out and and everything seems fine.
Any suggestions would greatly be appreciated.
marbra is offline   Reply With Quote
Old 01-24-2025, 04:46 PM   #2
oldbadger's Avatar
Right turn signal
I suspect you have checked all this, but here goes.
Do you have the right bulb for the right front and have you tested the bulb for function? How easy is swapping the front and rear and testing the function? If you swap them and the front blinks rapidly you know that the bulb that doesn't light is dead.
Have you checked the fuse for the turn signals?
good luck
oldbadger is offline   Reply With Quote
Tags
turn signal
