Old 07-17-2021, 06:43 AM   #1
DIY: Opening the Top Manually
Put together a little DIY guide on how to raise the convertible top manually in case something breaks and you are stuck out in the elements.
https://youtu.be/8l6tD5n3keE
1998 Boxster
2015 BMW M4 Dinan Stage 3
2016 BMW S1000XR
2015 Ninja 300
TTGator is offline   Reply With Quote
Old 08-06-2021, 08:12 AM   #2
Old Car Guy
vetman's Avatar
Push Rod for Convertible Top Transmission Pivot
The link with the red socket disintegrated but worse, the ball it attaches to came off. It is held onto the bracket with a nut and I have tried every position with the top and I cannot get my hand in there to even start the piece. Has anyone done this that can point me in the right direction as how to access this?
a tip, if you are replacing the rod, don't adjust the cup on the threaded end, use the nut to adjust the length because mine broke after 1/4 turn. luckily, I now find eBay has just the socket ends.
thanks in advance
Ray in Ellenville, NY
Old Car Guy
vetman is offline   Reply With Quote
