Old 04-04-2020, 04:22 PM   #1
DIY: Oil Change
Finally got around to changing the oil!
https://youtu.be/sO9JaAQ9Cvs
1998 Boxster
2015 BMW M4 Dinan Stage 3
2016 BMW S1000XR
2015 Ninja 300
TTGator is offline   Reply With Quote
Old 04-05-2020, 02:08 AM   #2
traveno's Avatar
Gotta say I'm a fan of all your 986 videos! Thanks for all your work.
2001 Tiptronic S in Speed Yellow
traveno is offline   Reply With Quote
Old 04-05-2020, 03:43 AM   #3
Thank you!!
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 04-07-2020, 12:50 PM   #4
98 Arctic silver 986
tommy583's Avatar
I have the same oil catch pan. After the first time I used it and splashed oil all over the place I modified it. I made the hole about 4 inches across, then i got some wire mesh and cut it to fit the whole size of the pan. No more splash. The wire mesh keeps the plug from going into the pan if you were to drop it. Works like a charm.
Old 04-07-2020, 12:56 PM   #5
Hey, great idea!
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 04-07-2020, 01:45 PM   #6
I also have the same catch pan. First oil change I did in the Box (in about 2007) I had the drain plug fall into the opening (which now no longer qualified as an "opening"). Ended up with most of the old oil on the driveway, a MAJOR clean-up. I also have, on subsequent changes, had that huge splash seen on the video when the drain plug first comes out.
Tommy's modification is more elegant, but what I did works just fine as well—and was easier.
First off, right after the first change with the major driveway spill, I got my electric drill, attached the biggest bit I had (1/2") and drilled maybe a dozen holes in the gently sloped surface that surrounds the central hole that I accidentally plugged on my first attempt. So now, if I do the same bone-headed thing again (I haven't, so far) it really doesn't matter. The oil's got lots of other holes to drain downward into.
The second thing I did was to take a 1 gallon plastic milk carton and with a box cutter carefully cut out the bottom and just below the top, ie I removed the plastic handle and the small opening that had been used to pour milk out of. Now I had a "funnel" of sorts. It was actually just a square tube that's open at the top and bottom. Now, before I pull the drain plug, I center the carton over the central drain hole in the catch pan surface. I carefully align it so that when the gusher comes out it goes right into the carton, so the splash is contained and goes nowhere but down into the center hole (and the 1/2" holes I created). Has worked well. I still always place some newspaper below the catch pan, but I virtually never need it. I rarely spill a drop anymore.
Frodo is online now   Reply With Quote
Old 04-07-2020, 02:05 PM   #7
Another excellent solution!
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 04-14-2020, 05:20 PM   #8
I use a Concrete mixing tub.. as my catch pan.. works great.
mikeinmass is offline   Reply With Quote
