Help pcm 1 radio unlock code
Hi i have a pcm1 in my 2001 boxster and have lost the code the details are
be 2580 y5041423 can any one please help |
you can try 4710 and if that doesn't work try 4698....
Heiko |
Bumping an old post I know - sorry, but I can’t find my PCM code (I found the nav code) and having disconnected the battery.
unit serial no. PO8000143499/09 MLFB; 5WK 78000A Or is this a drop into a Porsche dealer to look up? Thanks guys |
Old post I know, but wonder if anyone can help?
I thought unlock codes were not possible with the PCM1 from the serial? I'm hoping I'm wrong. I bought the car and the owner said he would get the code from Porsche, however the code is not working. Remembered he had the PCM1 replaced as he had the dead screen on the original. The replacement unit is as follows.... BE2580 Serial: 15089049 MLFB 5WK 78015 Now, if I can't get a code, can I simply use the working front panel/screen on the original head unit? Thanks in advance. :cheers: |
| All times are GMT -8. The time now is 06:22 AM. |
