Old 09-27-2017, 07:01 AM   #1
JT1
Radiator fans
hello , one of my fans has died. Does anyone have any idea of the diameter of the fan rotor as I've a mind to try and replace it with something other than OEM.
JT1 is offline   Reply With Quote
Old 09-27-2017, 09:19 AM   #2
I know you are probably trying to save money but I would find a used one if I could. if you toss a one of those slim line ones it's not going to have the shroud to direct all the heat through the radiator. It might not over heat but it will probably run hotter.
2003 Boxster S
997 Turbo Front End Conversion
Widebody Rear Flares Aerokit II Side Skirts
18x9 Front 18x11 Rear Wheels
Twin-Turbo LSx Boxster :troll:
Lcrivers816 is offline   Reply With Quote
