Old 05-31-2017, 03:34 AM   #6
Not sure what an adhesion promoter is. I sanded to remove all the damaged clear coat and scuff up the surface, cleaned thoroughly, applied self-etching primer as the sanding removed a good bit of the clear coat which got me down to bare metal in places, color, and clear coat per duplicolor's instruction.
What's an adhesion promoter?
Edit: Googled and found adhesion promotors. Fancy term for primer, and may just be for painting plastics. Duplicolor describes theirs as "ideal for automotive plastics". Similar language for Rustoleum.
Cbonilla is offline   Reply With Quote
