Old 11-15-2016, 06:08 PM   #1
Murph
Cowl drain
98 Boxster Base. While cleaning the cowl drains today I accidentally pushed the drivers side tube boss under the sheet metal. Attempted to recover from above, that turned out to be near impossible because of the brake master cylinder bracket. I'm concerned that if left this way who knows where the water will end up. Any ideas?
Thanks.
Mike Murphy is offline   Reply With Quote
Old 11-15-2016, 08:43 PM   #2
Good luck with that! Don't worry about it if you can't find it. You'll be fine.
Old 04-12-2017, 05:25 PM   #3
Mike did you ever figure this out? I'm having the same problem!
Syracuse986 is offline   Reply With Quote
