Old 04-07-2016, 07:23 AM   #1
Headlight question
Recently purchased a 1999 Boxster with burnt out lenses on both lights. My question is will 2003 Boxster headlight assembly fit on a 1999 Boxster? For some reason the price difference from numerous parts suppliers is about $200 per side!
Thanks in advance for any answer!
coachcrump is offline   Reply With Quote
Old 04-07-2016, 09:08 AM   #2
98 Arctic silver 986
tommy583's Avatar
Yes it will fit. On the interwebs you will find a WIDE variance in prices for almost everything sold for this car.
Old 04-17-2016, 09:44 PM   #3
Found some Hella Xenon headlight assembly online and are more than likely going to get them. My question now is the Headlight Corner Trim. I assume I should get the clear ones but all say "Only for Cars with Halogen Headlights" will these work? Here are the links to both the assembly and the trim. will both of these fit and work together?
Assembly HELLA 010054031 & HELLA 010054041
https://www.rockauto.com/en/catalog/porsche,2001,boxster,2.7l+h6,1374836,body,headlamp +assembly,10762?a=Ad+Code+G
Trim Automotive Lighting Headlight Corner Trim - Left Part Number: 137-08001429
03 2003 Porsche Boxster Headlight Corner Trim - Body Mechanical & Trim - Automotive Lighting, Genuine, Left, Right - PartsGeek
Thanks again for the help
Old 04-17-2016, 10:27 PM   #4
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by coachcrump View Post
...but all say "Only for Cars with Halogen Headlights" will these work? ...
The reason for that statement is that in some jurisdictions (mostly Europe) it is required to have headlight washers if you have the Xenon headlights. Either type of corner piece will fit those headlights fine. No sense in having the hole if you aren't installing washers.
Old 04-17-2016, 10:27 PM   #5
Never mind...I read the wrong part #.
Old 04-17-2016, 10:38 PM   #6
78F350's Avatar
Yes, they will, but the headlights you linked are way overpriced.
These are cheaper and the exact same thing. $789.95 shipped for the pair.
Porsche Boxster 986 1999 2004 Headlights Front Lamps Pair LH RH | eBay
That's what I thought until I read the post again and saw the lights.
