seat separation
Hello, im starting to redye my seats and seperating top from bottom would work best. Hows a good way to do this? Is it easy to reassmble or should i not try taking them apart? Thanks
Would also like to know this, but for the purpose of putting heated pads in for heated seats.
The bottom cushion comes off the seat frame relatively easy. Remove the control panel and the two white clips that secure it to the frame. Slides right out. After you get the bottom off, the center cushion and upper cover come off. 5 minute job once you know what you're doing.
http://986forum.com/forums/general-discussions/59401-separating-seats-shipping.html
Here are the same instructions Woody provided with pictures. |
| All times are GMT -8. The time now is 07:27 AM. |
