Old 03-15-2016, 09:22 AM   #1
How to remove a car wheel, check tyre condition, thread depth and inflate correctly
Maybe a little simple for readers of this forum but I made this video for completeness sake if someone is starting to work on their car for the first time.
https://youtu.be/JDksAkO3eO0
These are the tools you’ll need
Breaker Bar
Socket set
Anti seize paste
Pressure Gauge
Compressor
Thread depth gauge
Torque wrench
And the locking wheel nut if your car has one
The first step in removing a wheel is to loosen the wheel nuts. Take a breaker bar and the correct socket size then turn anti-clockwise.
Next you’ll need to raise the car (my video on this is here https://www.youtube.com/watch?v=La6i3TwMB8k)
Undo the wheel nuts and remove the wheel
If the wheel is stuck to the hub then you can give it a gentle kick to loosen it.
Inspect the wheel for problems such as excessive wear, cracking and objects like nails that could be stuck in there.
Rubber perishes over time so most manufacturers recommend changing your tyres if they are over 10 years old.
To check thread depth insert the checker as show and make a note of the reading. You can do this with the wheel on the car but it’s easier to do when it’s off.
The thread on a tyre helps move water away from the tyre when the road is wet. Most tyres start with 8 millimetres of thread depth on them. As I record this the legal limit in the UK is 1.6 mil and you will fail a MOT if it’s less. The general recommendation is to consider replacing tyres when the thread depth is down to 3 millimetres as below that tyre performance in the wet becomes much worse.
Put some anti-seize paste on the wheel hub to prevent the wheel sticking to it in the future.
Put the wheel back on and hand tighten the bolts. Always tighten in a star motion.
Lower the car then, using a torque wrench tighten the bolts to the correct torque – your handbook or manual will tell you. For my Boxster it’s 130 Newton metres.
Now we will check the tyre pressure. To find out what pressure is correct for your wheels look in your handbook or on the car itself. On a Ford Fiesta the pressures are located near the door and on my Boxster they are under the bonnet.
If you just want to quickly check the pressure use a gauge. Just remove the dust cap on and press the end of the gauge onto the tyre valve.
Over or under inflated tyres will result in less grip and uneven wear.
To inflate the wheel unpack a compressor and connect to the car’s power socket. . Use the buttons to set the desired pressure and then connect the other end to the tyre valve. Press the Start button to start the device. It will stop automatically when the desired pressure is reached.
Once done remove the compressor and put the dust cap back on.
If you liked this video the rest of the series is here: R&R
Any suggestions for future videos are always welcome.
neil_b is offline   Reply With Quote
Old 03-15-2016, 11:45 AM   #2
Top_Ramen's Avatar
Great "how-to", but also don't forget to check the tire for any signs of cupping and also if you're going to apply any anti seize on the hub, be sure to wire brush it first to remove any corrosion or anything else that might cause the wheels to improperly sit flush against the hub. It tends to be one of the biggest causes of improper torqueing of the lugnuts/bolts
'99 Porsche Boxster 986 - weekend car
'04 BMW 645ci e63 - daily driver
'98 BMW 528i e39 - dog carrier
Top_Ramen is offline   Reply With Quote
Old 03-15-2016, 11:57 AM   #3
I didn't see any mention of the lug bolt alignment tool. You really shouldn't change your wheel without using the lug alignment tool or you may end up with damaged calipers. The local Firestone just did this to my car and I had to repaint two out of four calipers.
Old 03-15-2016, 01:06 PM   #4
JayG's Avatar
You also should check for play in the suspension and wheel bearings before you take off the wheels
By the way, you spelled tires wrong
Old 03-15-2016, 02:29 PM   #5
You also should check for play in the suspension and wheel bearings before you take off teh wheels
Lol, tyres/tires, one of those Anglo/American things I guess...
Old 03-15-2016, 02:32 PM   #6
Thanks for the tip. Tell me more about this alignment tool. Is it supposed to come in the tool kit or do you have to buy it separately?
Old 03-15-2016, 03:09 PM   #7
JayG's Avatar
The Crown.............................ROW
Tyre......................................Tire
Boot......................................Trunk
Bonnet.................................Hood/Frunk
Hood.....................................Roof
Colour...................................Color
Drive on the wrong side.........Drive on the Right side
Spanner..............................Wrench
Blacksmith..........................Welder
Telly....................................Televisio n
Aluminium..........................Aluminum
Bollocks...............................Balls
Wireless...............................Radio
Bum....................................Butt
Derelict................................Bum
to name a few
Old 03-15-2016, 03:31 PM   #8
Porsche calls it the "wheel assembly aid". It should be in your toolkit.
Old 03-15-2016, 03:34 PM   #9
njbray's Avatar
Bullocks...............................Balls
to name a few
It is actually Bollocks! (bullocks are baby bulls) Don't forget Fanny! BIG difference in the UK
Old 03-15-2016, 03:49 PM   #10
JayG's Avatar
Fixed it, thanks
Bullocks was a department store in So Cal.
Old 03-15-2016, 09:28 PM   #11
Fintro11's Avatar
Ah so that's what that is for
Fintro11 is online now   Reply With Quote
Old 03-16-2016, 08:44 PM   #12
lkchris's Avatar
Indeed, the owners manual is for reading!
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 03-21-2016, 06:58 PM   #13
I've never understood why Porsche insists on hiding critical information in the owners manual. How do they expect anyone to ever see it?
'99 black 986
Old 03-22-2016, 09:18 AM   #14
2003 S, Arctic Silver, M6
paulofto's Avatar
Ahhh, more good old fashioned Winnipeg sarcasm. Gotta love it!
Tags
inflate , remove a wheeel , thread depth , tyres
