Old 01-27-2016, 06:55 PM   #1
How do I de-power my rack?
I did search, but help me, any good directions?
thank you in advance. Matthew
Sassmatt72 is offline   Reply With Quote
Old 01-28-2016, 06:39 AM   #2
The Radium King's Avatar
there are resources online for the 944 and the Miata on how to depower the rack, and most of the tricks appear to be transferrable to the boxster rack. if you are going to buy a rack to work on make sure you get the right year.
Old 01-28-2016, 02:52 PM   #3
It done.
That's what I realized.
I've pulled it, stripped it, did the ports, removed seals and rings...
and shipped the "torque" spindle off to CO to be fixed rigid.
pulled rack in an hour or so no need to remove any other part of the car (except wheels)
m
Old 02-04-2016, 06:13 AM   #4
Ben-Auto-Design
Ben006's Avatar
Did you weld the "flex joint" ?
What did you do for the PS pump ?
Ben.
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
Old 02-04-2016, 06:58 AM   #5
pinion shaft (flex shaft, torque variant shaft) ect ...
I sent the pinion shaft to martin willis @ the machine shop, Colorado Springs CO.
all the pro welding shops refused to weld on the shaft as it is hardened (they say) and the liability was too great.
He does them all the time for the 944 racers
(if it works for them, it will last on the street for ever).
I pulled the pump and lines, my application just needed a smaller alt belt.
Old 02-04-2016, 07:53 AM   #6
flaps10's Avatar
How much did all that stuff weigh?
flaps10 is offline   Reply With Quote
Old 02-04-2016, 08:39 AM   #7
Ben-Auto-Design
Ben006's Avatar
Nice to now that you found a shorter belt that fit !
What size was the belt if you now?
I've done it on my miata, and I really feel the boxster will respond as good to the modification (I like heavy, communicative steerings).
Thank you for sharing !
Ben.
1982 928 S Euro
Old 02-04-2016, 12:48 PM   #8
I've got a subaru EJ 2.5 in her so my application is unique.
Lines pump and fluid is maybe 10 lbs?
