Old 09-23-2015, 04:08 PM   #1
Horseshoe Console removal
How do I remove the horseshoe shaped console in the center of the dash? I've removed the radio but am stumped as to next step. Thanks.
oldlace is offline   Reply With Quote
Old 09-23-2015, 05:57 PM   #2
Beginner
Jamesp's Avatar
Iit snaps in. Get your fingers under the outside edge near the bottom and give a short sharp tug straight away from the dashboard. There are 4 snaps to do this way.
2003 S manual
Old 09-24-2015, 04:03 PM   #3
Horseshoe removal
Having followed Jamesp 's advice the switches popped right off. I then had 4 torx screws to remove from the climate control unit and the bezel came right off. Thanks for your help James.
Old 09-24-2015, 04:34 PM   #4
Beginner
Jamesp's Avatar
Glad it worked out well for you. First time I took mine off I thought I'd broken it.
2003 S manual
