Old 09-01-2015, 03:43 PM   #1
JayG's Avatar
Water pump and thermostat gaskets
Do you need to use gasket sealant when installing a new water pump and thermostat ?
Old 09-01-2015, 03:53 PM   #2
911monty's Avatar
If you bought the stock type embossed metal gaskets then, no sealant.
Old 09-01-2015, 04:17 PM   #3
JayG's Avatar
Thanks, that is what I thought
Old 09-02-2015, 07:58 PM   #4
Just curious, were you able to stick a torque wrench in there to tighten the WP?
hancock1701 is offline   Reply With Quote
Old 09-02-2015, 09:00 PM   #5
JayG's Avatar
Ill let you know this weekend when I do the actual install
just drained all the coolant and cleaned the front rads tonight
The front rads were actually pretty clean. Now I just need t remember where all the screws go LOL
Old 09-03-2015, 06:18 AM   #6
In case you didn't already know, there are two longer bolts on the pump. I made the mistake of not paying attention and had to go back and fix it.
Old 09-03-2015, 08:06 AM   #7
JayG's Avatar
I did, but thanks for the heads up anyway
